matth_85
I picked this thing up today. Figured i'd throw it up here before I feed it to the wolves on eBay...
2000 2500 Burb.
Good running 6.0L V8
4L80 shifts as it should and 4Wheel Drive works properly.
Needs a Drivers side PW motor, rear brake lines, struts for rear gate, and the rust holes in the rockers fixed if you care about looks.
Its from up north and is pretty rusty. Frame is good and all cross members are fine, just surface rust. The rockers are shot b/c of the factory steps holding the salt in so tight I assume. That and they are common to go in Yankee vehicles anyway... It needs brake lines on the rear because of the rust, there are some pin holes and it has a weak pedal because of this.
Anyway, it's cheap. $3000 Cash monies, or it's going on eBay soon so you can try to get it cheaper if your interested.
864-871-ZERO 44 FOUR
2000 2500 Burb.
