TJ/ZJ/XJ Front Axle
I am looking for a useable front dana 30. non-vacuum disconnect. 3.73 or 4.10 gears will work. I prefer something older that uses the large u-joint but I am not incredibly picky.
I could also use the spring and shock buckets off the frame if anyone has some they removed for coilovers.
