New battery in. Fired right up and purrs like a kitten. An old, asthmatic kitten, but purrs nonetheless.
I remember asking about stock tj battery hold downs. Back in 2012/13, I couldn't find them, but they're available now. This is what the generic rubber one looks like now
20180423_210413.jpg.
Can't get the factory one before Wednesday, so another rubber one for now.
Shoot, maybe I will stick with what I have a while longer. It's a universal one from the parts store but is similar to the OEM.
First trip with the trailer and I couldn't be happier. Thing handles like a sports car in the twistys. It reminds me of my old red drop spindle trailer, except this one isn't a home built piece of crap :smile:
My old winch rope is going on the trailer. I got this rope a while back in a FB auction and finally picked up a thimble. Now I need to figure out why the brake doesn't work on the 9.5ti.
Since I postponed the motor swap, I figured I should change the oil and do the semi-annual inspection.
The UCF skids have been doing their job.
And the rear sway bar and link took a pretty hard hit at some point.
Harbor freight press to the rescue again.
Not directly related to engine swap, so back to your regularly scheduled build thread.
I have more go and need more whoa... I swapped out the brake master cylinder and booster today. The master cylinder was leaking out the piston and the booster was rusting badly. I don't know if there was actually anything wrong with the booster, but I had the parts and was to that point, so I changed it anyway. I've only driven it a little bit so I'll report back. It does feel a little better and more consistent in its stopping.
I also fixed my ARB leak.
Pre-Moab to do list.
Last week I got my 9.5ti brake assembly in from Clemson 4 Wheel. I pulled the bumper AGAIN and disassembled the winch. The brake assembly comes with a new drive shaft but I considered not changing it because that requires removing the gear housing. I could see some crusty grease in there so I went ahead and completely disassembled and glad I did.
Brooks came by seeking refuge from their cold and rainy camping trip so he helped me get it regreased and back together. This time, I decided to test it before putting it back in the bumper and on the jeep. I bolted to an old reciever insert mount I have laying around, put it in the truck, spooled it half way in and pulled against the jeep with it. Brake held!
While the bumper was off, I swapped the power steering line that got into the crank pulley. In that process we lost all the fluid from the reservoir and I don't have any more so that ended the progress for the day.
new amsoil on the way. The brake on that winch works like a champ now!
I uncovered some ghosts of past owners pulling the stock cage. Someone had tapped in a couple speaker wires from the pods, by twisting and taping the connection, then put a short piece of wire in place of the cut and just twisting that too.
WTF Jeep?!
I twisted my security torx bit on this one. The other side came out with the twisted bit, but this one took vice grips.
All stripped down.
I got the new cage set in and some of the bolts started, but the windshield and the c pillars aren't lining up. I quit for the night before cutting anything.
